Just out of intrest how much were the bulbs?
iirc someone on here got charged £80 for a new bulb.
Hi there, i managed to get a pair of new bulbs off ebay for £50.
Dealer wanted £100 + VAT per bulb
I'm sure I've seen OEM cars with xenons and no washers. So I wouldn't worry about it. Just make sure they are aligned properly. Any MOT garage can do this for you. Do your xenons turn on corners?
What was the total cost including bulbs and ballasts and wiring etc? Are these not a £900 extra option from factory?
There won't be a new car on the road with factory fit Xenon's that doesn't have washers. It's illegal. Factory fit HID's like the new Civic may be different. But no new car manufacturer can fit Xenon lights without the level and washers being installed
I love what the OP has done they look fantastic and far better than the HID's on my car but they are still illegal and wouldn't pass an MOT (or an MOT done correctly)
HID and Xenon are the same thing.
HID stands for High Intensity Discharge, this is a high voltage spark in a bulb filled with xenon gas rather than a filament in a bulb filled with halogen gas.
There are filament bulbs that have xenon gas inside them, these are the expensive HID look alike bulbs that don't last very long like the philips bluevision etc.
The car in the pic is a Laguna, it came from the factory in 2005 with HID's that bend all the rules about projector lenses, washers and leveling systems. Go figure.
No these are not the AFS lights(ones that turn in corners) they are the ones with the chrome dome around the projector lense. I think it probably cost me around £500 - 600
for everything, quite alot but they look ace and ill get my moneys worth![]()
Rules have clearly changed since 2005 then.
Leon_MHX do you have any pics of the light pattern on the road at night?
might be interested in doing this, if no there is no proper aftermarket solution available.
2. when fitted to the vehicle should enable ECE Regulation 48 to be complied with (although no government inspection will take place).
Taken from a website you seem to know well Nath.
In the Department's view it is not legal to sell or use after market HID lighting kits, for converting conventional Halogen headlamps to HID Xenon. If a customer wants to convert his vehicle to Xenon HID he must purchase completely new Xenon HID headlamps. The reason for this is that the existing lens and reflector are designed around a Halogen filament bulb, working to very precise tolerances. If one places a HID "burner" (bulb) in the headlamp, the beam pattern will not be correct, there will be glare in some places and not enough light in other places within the beam pattern.
For the after market, a used vehicle cannot obtain type approval because it is only applicable for new vehicles. However we feel that saying "HID is banned in the after market" would not be reasonable. Instead we should make analogies with new vehicles. It would be reasonable to require HID in the after market to meet the same safety standards as on new vehicles. The same level of safety should apply.
1. be type approved to ECE Regulation 98 as a component.
3. Comply with RVLR as far as "use" is concerned.
In practice this means:
1. The headlamp unit (outer lens, reflector, bulb) shall be type approved to ECE 98 and be "e-marked" to demonstrate this. That can only be done by the headlamp supplier - Hella, Valeo etc. who must test the headlamp in an independent laboratory.
2. Once fitted to the vehicle it must have headlamp cleaning and self-levelling (which can be for the headlamp or can be in the vehicle suspension - some expensive estate cars have "self-levelling suspension" and that is adequate). Also the dipped beam must stay on with the main beam.
3. The headlamp must be maintained in good working order, kept clean, and aligned/adjusted correctly like any other headlamp.
Under the Road Traffic Act 1988 it is an offence to supply, fit or use vehicle parts which are not legal.
In summary it is not permitted to convert an existing halogen headlamp unit for use with HID bulbs. The entire headlamp unit must be replaced with one designed and approved for use with HID bulbs and it must be installed in accordance with the rules stated above.
I hope this information helps clear up some of the legality questions on HID's - cyb
So even though a complete Xenon unit has been replaced it still has to have headlamp cleaning & self-levelling. However the chances of this beong inforced are low, especially if like the OP the complete unit has been installed
![Cool [B)] [B)]](/forums/styles/seatcupra/oldforumsmileys/shades.gif)
Hi Leon_MHX, sorry dunno your 'real' name. I see you got yourself sorted out with bulbs and ballasts then. Nice stuff. My Xenons are still in the box at the moment. What did you do about levelling?? Are the blanks still in the lamps to hold the xenon beams or have you got them wired up to the rheostat on the dash? Thats whats holding me up at the moment, that and a 1001 other jobs the missus has me doing. Drop me a PM and let me know how you got on. Nice one....![]()
Well the Renault you featured does actually have washers for a start (they are on the bumper facing toward the lights) so that complies with point 2 in the ''in practice'' above. I would also imagine they have self height facility as this car sale for a 2003 car suggests, EX34 http://cars.trovit.co.uk/used-cars/renault-laguna-headlights-xenonSo can you give an idea of how that Renault and a few thousand others, came out of the factory the way it did.
