lesinge2k
222
Uttoxeter
Has anyone had problems with dup valves on cupras with or without a remap?
Got a bluefin fitted, and was wondering if it is worth upgrading to the improved oem one to prevent any future problems on mine?
i had a problem on my lcr after remap as standard dv wasnt holding boost pressure so was goin into limp mode
I would say it should be fine, and only replace the DV if you are having troubles.
Good advice, or spend £40 on one for piece of mind, an order the "D" spec valve (last part number is D on the spring valve rather than C on the original Diaphragm valve).
