Hi guys
I need to get some new tyres for front of my car, 2.0Tdi Sport 225/45/17.
Looking at Goodyear F1 Assymetric. I just wanted to check if I need to go with the 'high load' 94Y or if standard 91Y are OK? I ask because when inflated to manufacturers spec of 32psi look very 'squashed'.
Also, can someone confirm correct tyre pressures as I have same problem as others on here with high wear in middle of front tyres. I thought this is normally due to overinflation but normally run with 32/33psi.
I also have the tyre whine. I had wheel alignment done but can't afford to change all 4 tyres at present so hope at least these 2 will help!
Also just found nail in one of the fronts this morning so will need to get done as soon as!
Any help will be good
