ibiza 22
hi guys im haveing problems with my car any one got a guide to take the oil pick up pump off thanks scott
trust me you don't need a guide its that simple , its a case of removing the sump and the oil pick up is straight in front of you held in place by two bolts. easy!! might as well do the oil& filter while you are at it
im havein trouble takeing the sump off its like its stuck on ive taken all the bolts out as well any pointers cheers scott what bhp is ur car mate wat mods u got as well mate
The sumps are put on with sealant so it will need a little persuasion to get it off, i take it you've go the bolts that go to the gearbox out?
If you've got all the bolts out then you'll have to give it a gental tap with a hammer as suggested or try and prise it off with something.
