was looking under the bonett this after and thought i dont like these old plastic things ,, so thought chuff it ill make one lol
quick cut and weld and added a few pipes and a cap
then thought might as well add the washers on a sepete part so they will be hot water on the go
just have to make a quick bracket and another to top the washer bottle up /pipes poped on job done
not mutch just finished the header off ,and added a bit of vw washer cap ,,as im bisy with other stuff
also fitted all the water system pipeing apart fom ive a spare bottom hose heater matrix pipe and unsure were it goes , any ideas guys as ive not spare pipes left , or can it be re routed into the bottom hose?or something
hit a few probs with it over heating today/grr, as id piped a few pipes wrong and needed a one way valve adding
few bits of piping /one way valve for auxity pump
then i had a trail rev for 10 mins and it over heated reason was the single fan carnt cope ,(on its own /but seemed ok and test run,) so added 2 buggers, and all is well
caddys coming together at last
god im fed up , this ecu has started playing up yet again , as im runing low inpendance injectors ,the ms unit has a built in curcit to make them run , as im sure its gone faulty due to major over fuel and dosent matter what i try to do ,its missing and smokeing like a deisal , so i may have to bypass this and run high inpendance ,,
then while tuning the spark and fuel maps , the engine started smoking badly , i thought the worst .but found the problem which was the turbo oil feed hole was too big (8mm ) which was bypassing the turbo seals so added this one
and also fitted a 90 elbow too , so thats sorted that problem out , no smoke , lol
then got the laptop back on the go to find , my air tempture not working so went hunting at the local scrap to find one , made a new therd and fitted and works a dam treat too ,,
(all these little things do help trust , just awaiting now to try a new ms part , if i get no luck il thow some high inpedance inejctors in , fingers crossed one or the other sorts the problem ,,
right guys that the full homemade therd up to date , (8months its tuck me so far , not too bad timing i reckon ,,
Wowsers.. i'm not sure i'd have the patience to do all that let alone the mechanical skills.
good work, I'm looking forward to seeing the end result.
good work!!!! :clap:
have to admire you for taking on such a project!
on a side note, is that intercooler big enough for that mahoosive turbo?
Mig wire sales must have gone throught the roof with all that home done miggin!!!
Like i said a few pages back (LOL!!) looks awesome! Top, Top work!!! Good Skills!
cheers ok for a first attempt i reckon:)
unsure when that mabe but ill keep everyone posted
not hard more of a fun idea i reckon , interccolers ratted to 450bhp but that can all change with the fueling ,timing,turbo map etc :D
looks amazing, keep it up!
cheers i keep trying
absolutely loving this, cant wait to see the finished article!
nice one adam ,, its ok , fingers crossed it works lol
wow top work mate will be watchin this one:D
i think i will be too , lol with the amount of replys ,,
puts mine to shame
this is only homemade /cut/chop /modify and weld it togther ,[B)]
oh yes i worked it out used 4 big reals of 0.6mig wire , so a fair amount of welding/modifying/beefing up in surtain places , (still may need a bit more yet too;)
Looking amazing mate, great job you're doing there.
all takes times , i keep trying for every bit of time i get free ...
bloody hell good work took a while to read through all that.
wish i had your knowlege and skills. look forward to the finished item.
cheers if u dont try u never know what ur capable of doing with a lump of steel;)
all fun ,
Top work mate :clap:cheers
What turbo are you using?
the turbo is a holset hx40 /t3 flange/3.5 outlet ,size (18 as really i needed a 16 but finding one was a nightmare , so maybe a late spooler , hernce the reason i made a twin scroll manifold , to sharpern up the pulse and spool rate /plus its a t3 turbo not a t4 ,, which helps for tighter gas spool ,i made the engine backfire on 2 clyinders today and it instantly boosted and i thought it was going to blow a hose off , sounded well nice with a arsome turbo whistle,,:lol:like i say everything u see and read , is gess work trail and errorr ,, [B)]
