looooking good!....need one for my tdi Fr...
Those boost gauges are amazing pieces of work!
Holy hell great job! I wish I had the time and effort to do what you guys pull off O_O
Cheers mate!I'm still not happy with the fit of the boost gauge but its all plumbed in and working great so its alright for now. Just need a better fitting DIN plate...
get a din blanking plate from sere (seat part for the mk4) and drill a hole to fit the guage?
worth a try![]()
seat do a blanking plate (i have one) and then you would need to drill a the hole![]()
ive ordered the second should be here thursday will let you know if its any good or not mike.
did you use the little copper reducer thing in the t-piece or not? looking good as it is.
just waiting for my blanking plate then i can start fitting my boost guage.
out of intrest how much boost is your car showing would be intresting to know standard boost on an fr? as i beleive its not remmapped yet is it?
The car is standard on the engine front at the moment except for green cotton filter, Forge 007p recirc valve and drilled airbox.
Actually quite easy to fit into the centrevent, i broke the previous owners one so had to attack a new one with a 50mm holesaw and a dremel. Hardest bit is getting the boost pipe to go from the firewall to above the radio.
