Turbo pipes under inlet maifold
jammycupra
Had my car in for a service yesterday and the garage told me I had a split in one (or more) in the hoses under the inlet manifold. Explains why the car has been down on power. Iv had a look ad there are 2 with oil residue on them..
I want to replace them myself to save the pennies, but is it possible to do this without taking the manifold off?
ABM
Do you mean the breather hose? If so, Awesome do a replacement in silicone for that and the breather on the right hand side, both are prone to failing.
ABM
Yeah, I meant the breather below the inlet manifold. Comes as a set with the right hand side breather :)
ScoobyJawa
Achtung!
Oct 2, 2002
449
Liphook
Visit site
I did mine myself, its a bit tricky but doable, getting the circlips off is the worst bit. Those pipes aren't cheap from the dealer too, and don't forget you'll need new jubilee clips to re-attach
james walker
cooling is the key people
May 24, 2007
5,121
retford notts
just replace that pipe with sone vacuum piping from local motor factors.
i did and it cost £2.50 to fix.
youll have to remove a metal tray to get to it, only 4 allen key screws though.
pull the circlips off with the pipe, pull hard enough and they will come off the 2 nipples.
warninh one of the nipples is slightly larger than the other so you will need 2 sizes of vac piping... i just bought a selection....
Hamzilla
352
Watford, Herts
What is the left hand pipe that is next to the oil breather that is under the manifold?
Its taped to it further back but I don't know where it joins to?
It is made of the same crap so will probably fail also and I would like to replace it.
I have spent most of the long weekend trying to access the area under the plate and cut my knuckles to shreds.[:@]
Hamzilla
352
Watford, Herts
Sorry to bump an old thread but James could you please tell me (if you remember) where the second nipple pipe joins to? I have replaced one for the N249 mod but I can't work out where the other is going?
james walker
May 24, 2007
5,121
retford notts
the nipple under the inlet manny goes striat to the fpr when not bypassed, when bypassed you t off the fpr and to the dv top nipple.
Hamzilla
352
Watford, Herts
I have done the T piece from under mani to fpr which is under the right hand side but there are two nipples on the left hand side under the manifold. One is connected to the lower breather hose (which leads onto the rocker cover breather hose). The other is part of the PCV but I don't know where it leads to or which pipe it connects to.
This is an AUQ engine btw.
james walker
May 24, 2007
5,121
retford notts
the other one goes to the pipe that connects to the pcv valve, this one has larger diameter to the valve than the inlet manny nipple
greesha
Leon 1.8T on steroids
Jan 6, 2009
496
Slough
This one ? :p
Hamzilla
352
Watford, Herts
Ok I have edited my previous post as I was confusing everyone and myself. I will try and get a picture of it on here in the next few days.
