knight85
Money spending clown
Dec 30, 2008
2,222
South East
a few days ago the climatronic displays flashes when i start the engine. All the displays flashes up for a few seconds and then goes back to the previous setting i had it on when i last used the car.....any idea why?
also my intermittent windscreenwipers are quite unreliable now, they sometimes decide not to work?
any ideas?
cheers
the flashing climate control iirc mean there is a fault or it needs regassing.
as for the wipers err not sure, have you tried to change the intermittent speed with the switch on top of the stalk
doesnt need gassing as it stll works fine, just flashes for first few seconds,
yea have tried the changing intermittent switch, will book into seat i think under warrenty work
ok cheers, what sensor would it be?
wouldnt be anything to do with my boost gauge would it? As it started doing it few days after that??
unless you have tapped your boost gauage into the aircon the i doubt it would have casued an issue!
there are pressure sensor and temp sensors all over the a/c system so it could be anywhere
