are you on REVO code now? SPS unit?
no timing adjustment is shown in your screen shot of lemmi. I would pull out 3 personally from your CF's
You need to remove the second fuse in on the top row from the left. Your clocks will go off if you've picked the right ones.
The as dave said click read from ECU to see what your settings are then adjust and log.
cheers Phil
will see how i get on, I just uploaded a screen shot before! hadnt actually tried lemmiwinks or connecting it yet
presume its like vagcom, turn the key 2 clicks then try to read and change bits
got it working ok! turned the timing down 0.75 degrees so far so I'll log now and see if theres much difference
hello,
i've tried to use lemmiwinks on my mk3 cupra (and also custom-settings) and it's not able to connect.
i currently use a ross-tech hex-com interface, i've tried to remove the cluster fuse (the second one from the left on the horizontal line) and i still have the problem.
i was first thinking it could be due to the usb/serial adapter i use on my netbook so i tried with my old laptop (which use a pcmcia rs232 card) and still the same :(
Does anyone have an idea ?
Hi there everyone
I have been reading thought this forum and I am looking to get a little more power from my TT 180bhp.
I have been running my TT now for a year with no problems at all but now looking for a little more power and have a sps3 on its way to adjust my stage 2 map
I have the LiquidTT installed and have seen
Power = 223 bhp
Torque = 244 ft/Ibs
Air Flow = 170 g/s
Boost peak = 1.3bar
also got Vag-com today and was wondering what blocks i should be logging...
Just getting to the point now, I am wondering has anyone used lemmiwinks on a TT and is there any way I can get a little more power :)
Thanks Aaron
hello,
I`m having the same problem, did you solve yours?
Prebs
