Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Guest, 🎅🎄Looking for a stocking filler idea? Why not treat yourself or a loved one to our high quality CUPRA or SEAT valve caps.
my 04 ibiza mk4 has a puddle of water in the rear passenger footwell, what could be the cause? is it common? i have already checked the bungs in the chassis and there is no problems there.
no it doesnt work actually. but wouldnt that cause the water to be in the boot? its only the passenger footwell in the rear thats wet, everywhere else is bone dry. i just wondered if a water drain ran down there or something?
ive just had a quick look and the water pisses out the screenwash bottle, pump area when i work the rear washer so i think the pipe is broken/off at the front so wouldnt have thought it would be that, wouldnt get back there i wouldnt have thought. i dont know though lol what do you rekon?
A very likely cause in the seal on the door skin on the passanger side. If you remove the outer door card, under that is a skin that holds the window mech and stuff in place, I retightened all the bolts and put some odourless silicon around the bottom of this. It sorted my problem out. A new seal can be obtained from the dealers though. This happened on my 52 Plate 130 TDI Sport.
