do you mean splitter? under the front bumper
or
rear spoiler on the roof above rear window?
if splitter, it was probably screwed on, so undo these.
was not designed to go on the bumper type you have, based on sig pic, so had to be attached by other means.
for rear spoiler, need to remove inner boot lining to get at the screws, undo and remove. a few guides on advise to do this kicking about
For rear spoiler have to give the cover a yank off, then theres 3 X 8mm bolts, 2 are hidden with rubber caps, then theres 2 platic clips which release if you give it a pull, then simply disconect the 3rd brake light.
dont think so mate,
thanks lads, does the spoiler split in half, like top half and bottom half?
It does but it's not supposed to.
I did this partially to mine, oops.
There are tow bolts holding the high level brake light in, these are under pieces of tape. You'll need a long screw driver, aye very long and quite alot of patience.
Mine was a major PITA
