Is it an easy job changing the abs sensor?
So discs need to come off to get to the ABS semsor?
Ok i understand now. Will get the sensor ordered next week and give it a go. I presume you need to clear the code with VAG com to make the abs/tcs light go away after you fit the sensor?
