What is a Ko4-001?
slappy_dunbar
FrankenTurbo
Sep 1, 2009
91
www.frankenturbo.com
Last time i spoke CRT they said they use the RS6's KO4 components.
Is it possible they meant to say they were using components from the RS4, rather than the RS6? Getting a 42/56 compressor wheel inside a K03 housing is next to impossible. If they are recycling OEM housings the chances for a 2275-series wheel diminish considerably.
Not that it's such a great compromise to use a 2078 from an RS4. The MAPs are virtually the same.
Dec 19, 2006
673
If you do get time to do a write up jamie then I'll be reading it for sure, like you said different companies call it different things at least we'll be able to tell them what it is we want and not get confused lol so thankyou in advance if you do do it ;-)
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
I would just budget the new tip probably a lcr one in with the cost, (i should get a bit back from my lc one) i did know where to by a 80mm maf housing @ about £30 but cant remember where from now
Phil
If you keep intouch with the guys changing there MAF's on there LCR's you'll pick one up cheaper.
I changed mine, what Seat do is to charge you £15 extra then refund you this when you send your old one back.
It was no skin off my nose to give this to one of the Scottish guys who I was due a £10 to and a favour.
I'm sure others would be of the same mind.
I know you have persuasive ways
Phillc
Love is....Yellow
Apr 23, 2007
4,170
20
Pershore, worcestershire
Phil
:redface: Me persuasive [B)] well ok, if anyone with a LCR and changes the maf i would like the old housing PLEASE :wave:
