Re: no.1, point taken, although i was trying to get across the fact that people often make a decision on a component (the filter) based upon the performance of the (induction) system, which can be misleading.
The standard max airflow for a cupra would be about 442cfm / 0.209 cu m/s - that equates to 256g sec, although this assumes ideal conditions. I'd be making sure my induction system was rated for this flow!
Also, when you consider the max pipe flow speed of 23.94 m/s, that gives a min pipe diameter of 10.5 cm for anything feeding fresh air to the filter, or from the filter to the turbo.
BTW, the minimum required filter area for this flow is 74 square inches - not actually that much!
What diameter pipework do you have?
Also, it's worth bearing in mid you're increasing your inlet temp by not using a CAI so the speed of sound will reduce accordingly - sq.root (1.4 x 287 x Temp[kelvin]) - and necessitate a larger pipe.
An isolated cold air feed will give you a noticeable increase in power - as long as it's done properly!
