Been looking on auto bulbs direct at their hid kits, are thay any good? any one fitted one? do you have to drill your headlamps? ive searched the site but can only find info on mk1 leons.......
To fit the kit properly you will have to drill a hole in the headlamp cover to stop moisture getting in the headlamp. I got my kit from HIDS Direct and they have failed twice now, best kit I got was HIDS4U but are abit more expensive Other then that, straight forward job
Yes, as with any HID kit, basically unclip the cover from the back of the headlight and drill the hole to fit the rubber seal in to stop moisture, I went 6 months without my covers on as I never got round to doing it and still worked fine except the ballast died on my current set from HIDS Direct
yes. the plastic cover you take off to repalce your bulbs, you need to drill a hole through for the wires for the kit to pass through. had to make a 25mm hole for mine. guessing it will be similar if not the same for other kits. i did mine last week. was quick and easy to fit. literally about 15-20mins.
Bought them from Diane Shop , Drilled Holes and fitted them , Looked amazing
2 day later , They broke , Sent back and then sent a new set out , Ive had them a year without any problems , Im about to remove them from my Ibiza and fit them to the Leon (Hope moving them doesnt cause them to go pop)
