Dear Ladies and Gentlemen,
I'm going to replace my K03s turbo the next summer for a hybrid which would use the same housing and ancillaries and I hope will provide about 240-250bhp at the flywheel.
The car is a 2005 LFR (Continental European version of a LC), AUQ engined. Right now it has the following engine mods:
- Dimsport (Race2000) remap
- BKR7E sparkplugs
- Forge DV006
- Powerflex dogbone
- 105/110mm flex pipe to airbox
- Forge TIP + throttle body hose + PCV hose
- BoostFactory! uprated SMIC
- 3" Borla downpipe
- NewSouthPerformance PowerGasket+
- polyfoam-insulated hoses
- self-made grounding kit (120 amp rated wires)
Right now it makes around 210bhp top power just below 7000rpm with a very flat power curve (200bhp at 5000rpm, 202bhp at 5700rpm and so on) and 236-243 lb/ft from 3000 to 4000rpm, slight variations in absolute numbers are due to the place where dyno tests were made.
I'm interested into a hybrid using K04-023 wheels in a K03s housing, so that it would fit "plug & play" on K03s ancillaries.
The first option that came to mind was the APR K04 hybrid, which is quoted to fit AWD, AWW, AWP, AWV, and APH engines, but not AUQ. However, Awesome GTI sells it as a direct fit for Golf/Bora/A3/TT/Leon/Octavia.
I'd also be interested in a CR Turbo hybrid.
A remanufactured unit is not an option - it has to be a factory-quality item, profesionally balanced on a balancing machine by a reputable company.
Which other options do I have, strictly K03s housing hybrids, in an acceptable price range?
Thank you,
~Nautilus
- BKR7E sparkplugs
- Forge DV006
- Powerflex dogbone
- 3" Borla downpipe
Thank you,
~Nautilus
