Temp Display
RVP09
130
Morning chaps. I don't know if this is a problem but my temperature display keeps showing up in the morning, and every time I get in to the car basically. I normally just change the display back to show the clock, but even if I have been driving my car non-stop for over an hour with the heaters on full, it at some point displays the temperature again. It's annoying 'cos I have to keep changing the display to show the clock.
The temperature readings are usually between -1 degrees and +5 degrees. Might this have something to with anti-freeze? Or some sort of temperature sensor?
Any help will be appreciated.
Cheers.
Andrewcupra TDI
Resident Desk Jockey
Apr 30, 2008
3,282
in the mountains ( Wales )
yep is a little annoying but its there to warn you of the Temp
some cars have it displayed elsewhere
Why didnt seat but the click by the rear view mirroe along with a W8 light to start with
out this mornign and was showing - 8 :(
RVP09
130
it does that automatically under 5degrees C.
you'll also notice it has a snowflake symbol -> it's to inform you the weather is getting to freezing point outside...
Yes, that's exactly what comes up. And it's always below 5 degrees. So guess it is normal then!
AntneeUK
2 Wheels 2 Many
Mar 8, 2009
1,491
Nottinghamshire
This is something that's been getting on my tits for ages. Every 0.5°c difference it switches back from whatever I've got it displaying, back to the temperature. Seemingly even if it's getting warmer! I don't want to see it! Gah!
RVP09
130
:lol: I know how you feel Pal!
Deleted member 20376
yeah mine does it,
once when i cleaned my car it went to -50c i thought what the hell is going on there looked at the sensor i noticed it had fell out the clip and was hanging in the cold water lol. still cant see how it was -50c tho, they are never spot on but its helps sometimes i suppose. when ever the temp changes it flashes back up.
Andrewcupra TDI
Apr 30, 2008
3,282
can it be vagcommed then , its obviously been programmed to change
will have to get it hooked up when the weathers warmer and not -8 , even in the day its only -2 / -3
and i aint sitting in car fecking about :(
balls to that just play cod mw2 instead :)
Andrewcupra TDI
Apr 30, 2008
3,282
well here we go boys
altho it did drop to -8
mjt
365
it warns you when it's between -5C and 5C. it's annoying, especially when it's up to -5 after being below.
was particularly annoying in norway when it would quite happily sit there in the background with -15 but warning you when it's -5! :rolleyes:
Andrewcupra TDI
Apr 30, 2008
3,282
beet me then , but thants not uk :p
whose seen the lowest temps in the uk en ,
dont think the scots should play:whistle: its like this in the summer months up there :p
Kiirst
Monday morning when i left home my car said -7.5.
How accurate can the readings be though?
andypotts1981
55
-8.5 in the north east tuesday morning....
my car started no problem but my dads hdi picasso really struggled.... and he says an LCR is a daft car! lol
mjt
365
i think the leon's outside temp sensor is fairly accurate. it's certainly within a degree or 2 to our other cars and the thermometer outside the window
