Great results, Will
Did you log it on the rollers? What g/s was it pulling if so?
Hi Damien
I did log it, but only for boost and timing
Great results, Will
Hi Damien
I did log it, but only for boost and timing![]()
Yes indeed. I always accurate calculate the timing though, allowing a % correction for extremely high temps.
Do i get anything as i was the one to get the closest guess to the actual result![]()
Mine was 147hp standard. That was with PD160 intake, Green Filter and exhaust. Not optimistic seeing as most TDIs make over the manufacturers claims
I'm sure Mike won't mind, as he doesn't seem to be about at the moment..
He made 228hp and 230lbs/ft I think... sure he will confirm. As I mentioned to Mike though, on a normal day 215hp would be more like it.
Great figures Mike! Bet your pleased with the resultsHow does it feel to drive?
Graph looks good, im sure with a fmic and a map tweak, the power dip right at the end will hold better to the redline with less of a dip![]()
Looks much better now, Mike![]()
Thought you were looking at a oval tip?
Just need a down pipe and a FMIC now
Just been thinking that its been 2 years this month since I went for my stage 1![]()
