hopeing to get a bit of video on the go ,, ps i carnt go smaller wheels becuase of the disc and calipar size , and other things like sump , wouldnt be very good incase a speed hump appeared lol
Looks lovely mate, must be fun in the snow.
Ever thought of doing the wheels black?
u may have a point there , as i reckon , just spray them , either mat black or gloss black , think it would blend things in better :lol:
Yes do it will look good! Will you take this to any shows in the Summer?
hopeing so pal , unsure were yet ,but im also thinking of an ecu upgrade to the ms2 (techical ecu stuff lol) i think ill spray the alloys black least the discs and calipars will show up better ,ps if there any shows not a million miles away pop them up ill see what i can sort ,,
looks like there will be a few more updates to the caddy , which include , stronger engine mounts
ecu standalone upgrade to ms2
custom pistons/rods (when i blow these stock ones)
stronger pressure plate
modifyed turbo short runner intake
black wheels,
bit of exterior modication too ,
anyone who is thinking about useing stand ecu on there projects , i have to recomend [email protected] as the guy wrote the megasquirt software for stand alone ecus, theres nothing he carnt help anyone with ,and a geniune down to earth guy ,,,
after this its hit a few shows hopefully then a few spins down the raceway ... see what happernds or blows guys lol
Cool I would love to see this in the metal let us know as soon as you decide where to go. You could go on the stage at Edition38 and tell them how you actually built your car!
depends were its based pal , regards build thats easy chop chop shap and weld in lol
I think you should bring it down to GTi springfest at Santa Pod. Sounds like your sort of thing as you can run it up the strip rather than being sat in a field all day looking at 100+ cars that all look the same.
well time wil tel guys , as ive sent the ecu off to upgrade to the ms2 ecu ,,, heres some info if any off u fancy runing standalone ms
heres the link guys ,(for runing standalone megqsquirt ms1/2)
just contact phil on his homepage highly recomended guy, very helpfull, with help/suport, and he will suject best ecu for ur engines setup ,
(you,ll see a caddy pic of mine on there too, 27psi on a stand alone ms2 ecu ,,,
http://www.extraefi.co.uk/
http://www.extraefi.co.uk/gallery.htm
thought this would be of use as theres loads of standalone systems out there which are pricey to buy, the kits are brand new, and assembled to a high standed, as complete with labled wireing loom, instalation cd, etc ,,,as i know this kit was setup and tunied and runs/boosts a treat , once the niggy tunieing parts were sorted out ,,,
well my new modifyed ecu arrived at last,
this its a later version of the ms1 ecu , has better processor speed and more ram ,
16x16 tunieing tables , along with loads of differnert settings on it
upgrades 44psi map sensor, laurch control, vvt output to run my varible valve timing
and a qick pic too
hopefully runing again soon
Exellent work dude, hats off to you! :clap:
Have you managed to upload any vids?
well i blow the frigging laptop (dam got to it so , hopefiully ill get one of ebay to get the tunieing sorted ...:D and may get some snow/bossty videos on the go
and a qick pic too
You really do eat, breathe and sleep automobiles mate hats off to you!
having a few ecu problems at mo , setting it up , so its back to basiclys and check the crank trigger first
ecu looks nice inside too with its upgrades ,,
and attempt 2 tomorrow to get the buggar started fingers crossed
do it , plenty of info out there and regards ecu all the info/wireing/software is all free to download ,,
