vag radaitor water
mjt
365
water freezes at zero.
the temperature at which the fluid in your radiator freezes depends on the antifreeze
gb
here and there
Feb 27, 2007
1,852
136
portglasgow
dont really get whats hoing on here!!
james just with the cold snap that we are all having and the temps going down to between -10 and -20 i was woundering what the temp would need to be before the water in the radiator bottle would freeze just out of interest:D
NickT
429
LB, Beds
VW G12+ Coolant additive (the pink stuff) is rated as per the following mixture ratios (G12 is the 1st no, water is the 2nd):
2:3 rated to -24 deg C
1:1 rated to -36 "
3:2 rated to -52 "
truCido
Race Lupo in progress...
Dec 11, 2003
2,938
Bristol
www.vagowners.co.uk
If you read your post you asked what temperature water freezes at.....not anti-freeze. Thats why zero was mentioned :p
Like mentioned above it depends on the ratio of water to anti-freeze
adam cupra 20vt
Built Not Bought.
Mar 31, 2005
6,162
Mud Hut
It depends how much antfreeze you have and how much its diluted by.
gb
here and there
Feb 27, 2007
1,852
136
portglasgow
thought you werent ment to put antifreeze into vag cars because they have an alloy head or am i just reading something somewhere wrong[B)]
gb
here and there
Feb 27, 2007
1,852
136
portglasgow
i new about the g12+ it was just about the antifreeze a will need to check my owners log book:D
