Ah well, that's a different storyBecause it costs money that I don't have right now?
Splitpin, does he just put them on in the tricky bits or drive all the way with them?
Had one, got in to trouble, cleared it, don't touch them any more Why cant you get your summer tyres removed in December and put them back on in March/April like I and many others do?
For my Leon I picked up a set of alloys for £100, now I have the winter tyres on these so easy to fit and remove without using a tyre shop.
An ATB LSD wouldn't help you in this situation.
All a ATB (Automatic Torque Baised differential) does is magnify the grip one wheel has and switch it to the other wheel.
With zero grip on the spinning side 0 x say 2 is still 0.
This is where the new generation of ATB diffs come into their own like the Autotec Wavetrac.
If trying to climb this same hill again don't accelerate, just slowly feed in the clutch and slowly get going then get into second gear ASAP.
Also winter tyres would have got you up that hill.
But winter tyres and a differential and you would have been all the way home.
WHY DO PEOPLE NOT USE WINTER TYRES??????????
Sounds fair, I'll see in the next few weeks how the new Wavetrac diff compares to open diff and Quaife diffOdd that, because it's almost impossible to get zero torque on a wheel, even on ice. Even with a wheel off the floor and spinning, you still get some torque transfer.
I've got a quaife in mine, and on sheet ice that I couldn't stand up on that a coleagues tt was strugling to move across, I had no problem.
Slow progress admittedly, but clutch out, kept wheels slipping slightly, and made reasonable progress. This is on track tryes.
Had to take short run ups on some gradients, but i've seen Ranges struggle today.
TBD deffinately helps.
I have to ask, though, how you can tell that one wheel was spinning while the other had grip *WHILE YOU WERE DRIVING?* I know I can't see any of my wheels from the driving seat . . . . . . .
Ha ha. I'd managed to get the car over to the side of the road and one of the locals had cleared all of the snow around the driver side front wheel. I reversed it back on to the exposed tarmac and tried to drive. When I couldn't go anywhere I wound the window down and stuck my head out. I could see that it wasn't turning at all, whereas I could hear and feel that something was, so it must've been the other wheel that was on the snow still.I have to ask, though, how you can tell that one wheel was spinning while the other had grip *WHILE YOU WERE DRIVING?* I know I can't see any of my wheels from the driving seat . . . . . . .
