Bit of maths
http://www.theaa.com/motoring_advice/fuel/index.html
Diesel @ £1.137 x 55 litres = £62.54
Petrol @ £1.118 x 55 litres = £61.49
If you want a soot chucker with possible DPF issues, buy a diesel FR. If you want the same car that does not sound like a Massey Ferguson and uses more fuel while creating less smoke, buy the Petrol FR.
If you want to go faster than both, buy a Cupra![]()
Bit of maths
If you want a soot chucker with more torque than a battleship, buy a diesel FR. If you want the same car that does not sound as roarty and uses even more fuel whilst the fuel pump works and cost more to tax but creating less smoke but more expensive RFL, buy the Petrol FR.
If you want to go faster either chip it or buy a BMW 123d![]()
I'm going for the CR FL FR which doesnt have the DPF issues!![]()
I thought they had also fitted the dam DPF to the CR FR as well, Its fitted to the new Ibiza FR CR 143HP.I want the best of both worlds without it costing the earth to run so I'm going for the CR FL FR which doesnt have the DPF issues!
cheers matey
I will have to check Seats small print. .....................................!!
Im not sure what the point of JUST comparing pence per litre comes into it? What about economy? Work out the economy and then draught up the cost per tank in comparison!Bit of maths
Bit of maths
Cheers, thanks for clearing that up. I understand for Seat UK they will not be doing a DSG FR TDI in the Ibiza [ think it because the engine /trans is too heavy hence the battery in the boot etc.] which is a pity because I'm thinking of changing my Leon for a Ibiza FR but will need a semi auto due to my wife's recent illness, suppose I could go for the Leon FR DSG ???The CR does have the DPF but with the new common rail 1800 bar Piezo injection the engine burns cleaner and produces less soot and the knock on effect is the DPF is not working so hard or as likely to get sooted up. Very few issues reported with the CR DPF so far.
