Cupra TDI White Smoke @ low revs
MJ
Public transport abuser
Apr 22, 2008
5,508
13
Manchester
m.facebook.com
Many people have this. I had it on old leon, just let progress untill it becomes an issue then have a garage look at it or if i doesnt change then just ignore it.
Someone will be able to explain exactly what it is i.e. cool air becoming condensed in the combustion cycle thus producing the "white smoke" which in that case would mean its steam but i'm not 100% sure.
jonjay
50 Years of 911
Jun 27, 2005
5,843
Essex
Its normal the injection timing to help turbo spool up (I get this quite a lot although died down since new pipework). If its white smoke on idle then usually means oil seals are on their way out OR water in the exhaust system.
Lee g
164
Banbridge
I just got a hybrid fitted and mine has started smoking at around 1500rpm but clears when above this. Onlybthing ibcan think of is maybe the oil as it was changed too.
Apr 13, 2011
1,971
hull
That's what my Cupra tdi was doin when I had a boost pipe split on the lower side of my turbo.
Used to white smoke when settin off slowly ie it stop start traffic and also did it when In very low revs is cheak all boost pipes for oil residue around them if there is replace or upgrade it fixed my fault.
