excellent,cheers Lee just what i wanted to hear.
i just got mixed up with the gauges, i want one badly!
id prefer it in the vent but if get rid of my car be a carry on and every single person i know would want a go!
i wonder if could rent it out?:lol:
Done a TB re-set this morn using this thread and vagcom. I had some very slight hesitation pulling off from idle from cold and the re-set "seems" to have sorted it (only took a short trip to the shops)
Is this possible with the freeware version of VAGCOM? or do I need the full versio to access the correct part?
Had mine done today as I changed my inlet manifold last week, it must have been out to start with as it drives a lot smoother now.
Definatly worth getting it cleaned and reset IMO :)
Have you got the full version of vag com Adam? Would you think that a clogged up throttle body would cause hesitation? Just trying to rule things out. Might come and see you if you have the full version
guys....I found a lot of oil in the pipe otherside of the throttle body, I cleaned out what I could but it was quite dirty with oil too... is this normal? Anything you would recommend to do?
where can you get the full version of vagcom from????? i got mine off ebay few months ago to read faults paid about £40 for it but its not the full version quite p***ed off thanks
was it advertised as the full version?
if it was then I would understand your frustration, but if its not, then you knew what you were buying at the time....
