new problem with my coolant system
meltonlad
391
huntingdon
its to hot for me when sitting in the car with it on hi but i can still keep my hand cover the vent when on hi so it aint HOT HOT.
meltonlad
391
huntingdon
sod changing the CTS again cus that will make it number 5 in 12 months..... and im on my 4th stat in 12 months..... i will just have to keep an eye on it. thanks LEE69 :D
ThackersLCR
141
Blackpool
oh no! i cant be doing with that! iv got my local mechanic stumped aswel. part just arrived so will be fitting in a minute or two. im going to compare readings on both sensors by testing continuity when cold and hot, im still not convinced its the cts though.
mjt
365
When I mentioned this to my dealer last year he said that it was the instrument cluster..
I was sceptical at the time, but if you're still experiencing problems after replacing the thermostat and the CTS, then a new cluster could be worth a look..
mjt
365
FWIW, I had a computer hooked up to my car last week due to a boost leak and/or failing turbo, and it turns out i have a CTS error..
So yeah, CTS sounds about right :)
