Minimum disc thickness on 1.9 FR 130 (05)
Neo
Fool member
Mar 24, 2009
881
7mm I think. New discs are 9mm thick and the recommended min thickness is generally 2mm less than new thickness.
+1... Exactly what he said.
Need to change mine, have`nt checked the thickness but there`s a huge lip at the edge!
Jan 11, 2005
680
Barnsley
Same with mine. Seems to have got much worse after the winter we've just had. Can't compain though, they've done 71k miles :)
Neo
Fool member
Mar 24, 2009
881
Yeah mine are on 76k, but I imagine the rears last longer than the fronts on any car.
That said I`m not sure if my front discs have ever been replaced!
Nearly got all the parts together for my 312mm conversion so I`m putting all that on the front and replacing the rear discs at the same time.
Jan 11, 2005
680
Barnsley
I got about 38k out of my front pads so had them replaced and they squealed all the time because of the lip that had worn so I put new discs and pads on at about 42k I think. The discs now only have a few thousand left on them now so I'm pleased with the wear rate
