Not sure what FKs they are TBH... another cheapo ebay bargain I found! Will attack the adjusters next week. The Ibiza FR ride isn't the most comfy anyway, so not sure what to expect with these. Bought them mainly to get the arse down...
I hope you've got a good dental plan! Yea, WD40 will do the job if you give it long enough to work.
The "shock and unlock" should do the job quicker though.
Non dampening adjustable and not stainless steel then they're Highsports.
Dampening adjustable and not stainless steel then they're Konigsports.
If they are stainless steel then I think they're called Silverlines
Will give it a go, not in any real rush. Was thinking about painting the springs and giving them a bit of a tidy-up. Not sure I want to free the adjusters yet anyway...
They must be Highsports then! The front dampers have a bit of surface rust (so I assume they are not stainless....) How much thread have you got below the adjusters at the front? How about the rear? I like your stance Altech.![]()
Thank you
Iirc up front the adjuster sits 20mm from the bottom of the thread. The rears are wound right down with the adjuster still in place. I've now got my standard wheels fitted so had to raise the car 10mm all round
These are set about 10mm from the bottom of the thread. Might leave them in place TBH instead of moving them. Rear adjusters are all the way down so might just leave them too. These are sounder better by the minute... but the acid test will be fitting them to the car and after a few K of miles really!
They are currently sat in my garage....
I've told you before Mike, you can't do this to the children!.....
Gooner, can I ask what Lowering springs you have on yours? They look a perfect height for what I want. Also, what is the bumpiness like compared to standard? Need to get mine lowered a little bit as the front is far too high compared to back. Many Thanks.
i take it this only increases noise and is for nothing else?
Just love hearing that turbo whistle.... i take it this only increases noise and is for nothing else?
Don't forget the weight saving benefits too
Don't think I'll be doing this to my derv powered beast, if anything adding extra sound deadening to mine would be better![]()
