http://cgi.ebay.co.uk/AUDI-VOLKSWAG...s_tyres_Trims_Car_Rims_ET?hash=item20af6bfddb
Anyone know if these would be suitable for an LCR with standard rims?
Id look on there for the hubcentric ones,they are the same price.The hubcentric ones bolt to your hub then you bolt your wheel to the spacer my personal opinion is this is safer rather than having longer bolts holding it all together.![]()
Hubcentric can still be used with the longer bolt, through the wheel/spacer.
Swoosh have u got BBS CH? et35? i have and im having to run 15mm hubcentric just to achieve 1mm clearance on the brembos, and im only just legal with the tread of the tyre under the arch.
I know but there are spacers on ebay that bolt to your hub, ive got them on both my cars there is no need for longer bolts then![]()
I know that but others don't.
You said hubcentric bolt to the hub, well, they can do, but they also can be a "through" bolt![]()
Hubcentric are deffo the best option as u have the rigidity of the hub - circle as well as the bolts.
Does anybody know how wide to go on standard LCR wheels with 30mm drop on standard height?
I would like some like these: http://cgi.ebay.co.uk/20MM-Hubcentr...emQQptZLH_DefaultDomain_3?hash=item439d64316c
so i can use standard bolts and lock bolts.
But is 20mm too wide for front and will it sit inside the rear arch? I cant see any bolt to the hub ones that are less than 20mm..
I was thinking 15mm like you have but ideally want the bolt on ones like in the link but can't find 15mm versions not sure if they make them as the bolts wouldn't hold or not... I'm prob not as low as yours I doubt as down 30mm to standard using 50mm springs so don't know what the clearance will be like.
On another note did I see you lash month around bury?
Should think I did see you as it was that weekend! Well yeah that's handy they stay there then but it's just the fact that I would rather use the shorter bolts and locking bolt rather than longer ones
