I have 15mm on front which are hubcentric but they dont bolt to the hub. the kit comes with longer bolts.
I have 20mm rears which do bolt to the hub.
I have no wheel wobble whatsoever, and it drives as it would with no spacers.
which 1s did you use and have you got alink:)
I bought the set that you linked to ebay in the first post and I have to say avoid like the plague! They are awful! Spend a little more and get some from the likes of Forge or H&R etc where you know you will get quality.
i have got H&R hubcentric spacers on mine a quality peice of kit very well made and so light its untrue anything over 5 mm and longer bolts will be required just give damien at DPM a bell he can sort out full kits including bolts H&R all the way for me
Can anyone confirm for definite that 11mm Forge Hubcentric Spacers fit the rear hubs of a LCR ok? I've heard and read there may be an issue with the hub "lip"
Would be much appreciated
Thanks!
George
Haha :). I want a definite answer! I thought if I bumped each one then the previous posters would get an email and maybe one would have the answer :)
George
