correct tyre pressure
bigman75
211
Wolverhampton
Hi Goggen
The pressures to use are printed on a label stuck to the inside of the Fuel filler flap. Or at least mine are. I don't have a Cupra though.
Pressures vary depending on load (Passengers/Luggage.) If I recall, it ranges from 29-32 psi.
Andy
Busta
66
depends how much does do you carry in the car, BUT also how thin is the profile of he tyre. If you are running 17" (215/45/17) it is highly reccomended to go little bitt higher cause each hole you go in will be a dissaster for the alloy wheel...
WozzaM
48
Malta
Listen to this man. I learned the hard way.
vtxracer
409
13
Greece
What is the correct tyre pressure for the FR/cupra ???? Mine says 33psi
But other Fr and cupras have this (thanks to Mr.Linatsa69 for the 2nd pic)
spikeydoo
not such a newbie
May 19, 2006
259
Somerset
I wasn't sure so I've just been out tot he car to check, & mine are 2.5bar front & 2.0bar rear, for the normal load - so different to both of those images?? Mines a Boc but can't see the tyre pressures being any different??? What do other have?
EdHorny
Loves his Boc.
Oct 12, 2008
453
Burntwood
I keep my fronts at 2.1 bar. that's what it says on the filler sticker.
ED
mainaman
116
London
On the Cupra-36/29 or 41/36 with five people onboard.
When i got my car it was 40/32,now i am driving at 39/31 and i don't find it overinflated.
Seat's recommended 36/29 sounds suspicious to me as the front is too heavy and the tyres look little flabby at 36.
vtxracer
409
13
Greece
My tyres look ok with 33psi. (215/40 17") but i dont know why there are diferrences. So some have a diferent sticker than the ones i posted ?? Could you upload a pic ?
spikeydoo
not such a newbie
May 19, 2006
259
Somerset
This is my tyre pressures, I'm actually running 1bar higher on the front as they looked a little low:
Just so it's easier, all in one post:
643
Dorking
my car was delivered with random pressures all round, lowest 23, highest 47! i now run 44 front, 39 rear to get a smaller contact patch - its a trackday thing.
EdHorny
Loves his Boc.
Oct 12, 2008
453
Burntwood
My label doesn't seem right. I got the usual Pirelli P7 215/40 R17's on my Boc, noticed fuel consumption was a bit more recently and put it down to my right foot. It's usually just me in the car and so keep them at 2.1 bar, may raise this a bit.
ED
jc_boc
Missing the CUPRA R!
Jul 18, 2008
9,304
7
Desborough
I am amzed at the vast different in pressures being shown. I can understand that dependant on various tyre sizes it would be diferent but wow, there are some outrageous differences there guys...................... Should we get a list of them by car so BOC = so much. Cupra, FR, TDi, 1.6, 1.4 etc. I guess we should add the tyre sizes in there too.
