Driving "off the turbo" would involve keeping well below 2000 rpm, and even then you'd get some boost.
Not true, you can drive along at 4000 rpm (or higher) in 5th / 6th gear with 0 boost.
So yes, there is always 'boost'.
Electronically switching off N75. Is that safe for a long trip actually? Does it really give any better mpg?
No, because 'boost' is increased manifold pressure above atmospheric pressure.![]()
Surely the best thing to do is to turn off everything thatis not needed including heating, lights, stereo, air con, rear screen heater etc. I can't see it being worthwhile getting a seperate map for economy if you are only going to use the car for this journey for about 6 months as you wouldn't gain the difference back in fuel.
Air con is the biggest one, followed closely by the rear heater. The other are negligible when it comes to fuel economy. Did you ever see Jeremy Clarkson taking a Jag to scotland and back on one tank of fuel? He was happy enough to be warm and listening to music while he did it.
nope, not a jot on cruising as you are not on boost anyhows
im doing a lot more travelling due too a new missus, and i cant bring myself to buy a diesel, i want to keep the 20vt, and to see if i can increase the mpg even more
Its not all bad, mine goes like stink and I even managed to get 54mpg on an 80 mile trip the other day.
54?! bloody hell, did u push it half the way or something?! haha
Originally Posted by Muttley
andycupra DID NOT write (it was Muttley)
