should be easy enough to get some adapters considering how common they get VAG fitted
Do they fit over the brakes being 15s?
£135 is for a pair i think. Doubt you will get 4 for £135 unless used. Even then they go for more than this.
I stand corrected.
Is 15mmm enough of an adapter on them? They going to sit flush with the arch?
Just checked an offset calculator and doesnt look like they will be any change. (standard wheel is 7" and ET37 yeah?)
I stand corrected.
i dont no if i will be able to but for the rear i was thinking about using 20mm spacers and attaching the addapters to them so the rears will be out 35 mm :shrug:
Offsets are about 55 on these arnt they? You want the rears down to 15 id say and the front 25-35?
Think the under tray will be on the floor on standard suspension :p mines rubs on normal roads sometimes and thats on 17's haha
getting a bit technical for me mate lol . i dont think i will be to far of the ground prob is i have loads of spped bumps to get out or my estate looking forward to getting them on
haha nutter, it will be fun getting over them anyway!
Id say 35-40mm adapters rear and 20-30mm front ones. They always pop up cheap for sale on the edition38 forum!
yeah al get them stuck on and see where i am from there just need the backs to be flush or a bit sticking out from the arches
nearly bought a set myself as they are £150 for a set with nearly new tyres. just don't have the funds and patience to get the spacers/adapters
i have been looking for a set for a while, there was a few sets that had been sprayed but didnt want it to start to peel and flake so thought getting a powder coated set would be better but they came at a bit extra cost
To get anything near a small arch gap the chassis and subframe will have to be touching the floor!!!!! I think a Scottish lad had some on a black Mk4 at Edition38 last year, in a dark red, not 100% sure if they were teledials though
