SalSheikh Under the Hood Sep 2, 2009 2,756 5 Midlands, UK Apr 8, 2010 #1 any idea's what size breather filter is needed if i am going to use an induction kit? looked on ebay and the sizes range from 9mm to 15mm thanks
james walker cooling is the key people May 24, 2007 5,121 2 retford notts Apr 8, 2010 #2 28mm iirc mate....
SalSheikh Under the Hood Sep 2, 2009 2,756 5 Midlands, UK Apr 8, 2010 #3 james walker said: 28mm iirc mate.... Click to expand... well, the closest i found was 25mm any links to the ones you guys have used/recommend?
james walker cooling is the key people May 24, 2007 5,121 2 retford notts Apr 8, 2010 #4 25 will fit ok, 28mm is a little loose imho..
gezmeister I need a derv!! Apr 1, 2008 2,172 0 Norwich Apr 9, 2010 #5 Yep, as james said, 25mm is fine. Have been using a 25mm filter for several months with no problems
