greck999
SLOW work in progress....
Jul 10, 2009
396
Rugeley, Staffs
Hi, has anyone had their Leon scanned with Vag-Com and its come back with unreadable sections where the modules at fault are. See below at my scanned Cupra R and see the section that has all different symbols/letters etc.
Hope somebody can shed some light and stop the cause....
Cheers. :shrug:
VAG-COM Version: Release 311.2-N
Chassis Type: 1M - Seat Leon
Scan: 01,02,03,08,15,17,19,22,35,46,56
Address 01 -------------------------------------------------------
Controller: 1ML 906 032 A
Component: 1.8l R4/5VT 0002
Coding: 10510
Shop #: WSC 66565
VSSZZZ1MZ5R021775 SEZ7Z0D2582409
1 Fault Found:
18010 - H(²>z¢]!.3PE[y[„zKQb6k…*\E{hñsO.]CHP~8`BH
P1602 - 35-10 - f - Intermittent
Readiness: 0000 0000
Address 03 -------------------------------------------------------
Controller: 8N0 907 379 G
Component: ESP FRONT MK60 0101
Coding: 0019469
Shop #: WSC 00001
2 Faults Found:
00287 - `‡/Oìi«ê8~ù@M¢A{6àh+Ú6'!x«–oÓg#Y<^¥c³d*š
003 - ?K#U@À"e4!TÉ23Ƈ¬; - Intermittent
00290 - Ÿ$5ì;-c v%9U3\òWEµ<d|s-l~ö[Á`¾J]ÚoË©h*
Address 08 -------------------------------------------------------
Controller:
Note: Excessive Comm Errors
Address 15 -------------------------------------------------------
Controller: 1C0 909 605 A
Component: 39 AIRBAG VW51 0A 0008
Coding: 13113
Shop #: WSC 06401
No fault code found.
Address 17 -------------------------------------------------------
Controller: 1M0 920 922 F
Component: KOMBI+WEGFAHRSP VDO V06
Coding: 05424
Shop #: WSC 00000
1 Fault Found:
01314 - ¡‘M?Õ;7pQDiU7JXf"÷—ß9
49-10 - h6ZI[UåôŠ{(sÏRùi[ - Intermittent
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 06402
1 Fault Found:
Address 46 -------------------------------------------------------
Controller: 1C0 959 799 F
Component: A7 Komfortgerát HLO 0004
Coding: 00258
Shop #: WSC 06402
Address 56 -------------------------------------------------------
Controller: 1M0 035 186 K
Component: Radio GRO 3 30
Coding: 00401
Shop #: WSC 06402
End -------------------------------------------------------
That suggests to me a corrupted VAG-COM install, especially because all the fault labels are messed up. The fault codes are coming back ok, but the interpretation is failing.
I would reinstall it and see if that helps. Or you could look up the fault codes on one of the many OBDII code lists on the interweb.
Thanks for the reply. I think i'll try and re-install it and see if that sorts it. Cheers for that..
