How much is this car up for can you pm me please looks awesomalso what redline mag issue was it in please
Car was in March redline. I think they are on the next issue now, but you can always get back issues from them!!!
I dont really want to sell it as ive been having so much fun with it recently, but new projects are on their way.
I will PM you now with the price.
Nice one on the feature Alex :) May have to get a back order myself to check it out. As people have said, awesome car and shame that you're selling. It'll make quite a weapon for someone else :D
Thought I should put the full spec list up:
Engine:
Bored to 1.9
JE 82.5mm 8.5:1 low comp pistons
IE forged conrods
Arp Main studs
Uprated sputter big end bearings
Supertech single collet inlet and exhaust valves
Supertech valve springs and Titanium retainers
Ported and polished head
BDM T-25 Exhaust manifold
Garrett GT2871r Turbo
Custom full 3” exhaust system with ceramic coated downpipe
SEM inlet manifold with Hemi 80mm throttle body
Audi S4 Airflow sensor
3 Bar Map sensor
ProAlloy Intercooler
Mocal 13 row oil cooler with Aeroquip fittings
Forge oil catch tank
Forge 006 diverter valve
Forge silicon water pipes
Seat Sport Baffled sump
Revo Stage 3 custom remap
Siemens 630cc injectors
Walbro inline fuel pump with USRT wiring loom
Powertech filter
Neuspeed lightened pulleys
Aircon removed
Vibratechnics race engine mounts
Gearbox:
5 Speed Gearbox
Shorter gears from a Golf Gti
Cryogenically treated gears
Spec Stage 4+ clutch with Alloy flywheel
Sigma 5 short shift kit
Shift box mounted in car
Suspension:
KW Variant 3 Coilovers
Rose Jointed track rod ends
Rose jointed wishbones
Rose jointed eccentric front top mounts
Powerflex black compound rear beam bushes
Front upper and lower strut braces
Rear upper T-45 strut brace
H+R front and rear anti roll bars with rose jointed links
Brakes:
Brembo GT Junior front conversion
Brembo discs grooved and painted by EBC
Ferodo DS3000 front pads
Rear 256mm vented conversion with TT callipers
Ferodo DS Performance pads
Braided lines all round
Ferodo Dot 5.1 fluid
Wheels:
OZ Ultraleggera 17” wheels with Toyo R888 tyres
15mm spacers front and rear
Exterior:
Heated windscreen
Retrofitted aero wipers from a Lupo GTi
Carbon Fibre bonnet
AeroCatch Bonnet Catches
Stubby drivers side mirror
Cut out front bumper
Carbon Fibre ‘S’ badge
Stubby Aerial
Interior:
Corbeau Pro series carbon bucket seats painted body colour
Schroth 3” 6 point harnesses
Custom made T-45 harness bar
WRC spec custom T-45 tig welded seat mounts
Flocked Dash
Sparco steering wheel + spacer
Blitz Type R Boost Controller
Defi boost and oil temp gauges
Vems AFR and EGT gauge
Seat Sport gear knob
Heating and stereo removed
No sound proofing
Carbon Fibre centre trim
Carbon Fibre Door Handles
Carbon Fibre dash pod insert
Carbon Fibre boot floor
Dry cell racing battery mounted in boot
Audi TT Pedals
Alex, is your Neuspeed crank pulley dampened??
Just linking this to http://seatcupra.net/forums/showthread.php?t=208928 :confused:
I've been considering the Fluidampr but undecided at the moment
Its not, but ive had no issues so far. I dont rev it silly high either. Been thinking about changing for a Fluidampr, but i dont have the money to spend on it at the mo. How much are they these days?
Deffo not cheap. I will be at Spring Fest. If you do go then give me a call when you are there.
Hey Alex, I've got one fitted, cheapest I could get it for was $370 from USP Motorsport.
Chap to deal with is Jeff and he is pretty quick in email responses.
On a different note what are your views on the NGK BKR7E Spark plugs, have you used them on your setup?
Hey Alex, I've got one fitted, cheapest I could get it for was £370 from USP Motorsport.
Still not cheap and have have no spare money to spend on the car.
I have used NGK plugs before with no issues. Then I have had no issues with the denso plugs as yet either. The iridium version of that NGK plug is also good.
The Ibiza needs to go now. I will be putting an add up in the for sale section. Looking for 12K at the lowest. If the car is not sold by the end of June then it will be sold in bits. I dont want it be broken up as ive put so much time and effort into the car that it will be a massive shame.
