first off thought id check the intercooler pipe fits a dam treat with clearance too , think ill tig a dump valve in there, also heated the plastic vacum pipes for the brake servo and re solderd all the wires and shorternd them,
next as i have a bit more room i pulled the exhust side in around 2inch ,(saves a rattle
then new turbo arrived so thought might as well make a manifold , first tempory fit ,
you,ll notice its on a angle reason is ive no room to run a dam boost pipe , ive an idea thow lol
few start pics of the turbo and manifold progress
didnt like it above so alterd it lol
Lookin real swell dude, I cream at the very sound of a VR! I have access to a VR lump myself and been toying with dropping it in the wagon!?
many thanks on the cool replies guys , i just have a go , mind since it rebuilt it from a bare block ive not evern tryed or heard it run yet ,lol , beer bad 2day so no real updates couple of pics of the manifold i had to make , just needs welding finishing off and external wastegat modifying , then ill get the buggar bolted up
Just discovered this... wow, speechless.
Your beetle looks ace too, surely you can't just leave that in the garage!
not too mutch but had a slight engine prob ( nothing bad ,just a stuck hydrolic tappit ) now runing on 6 pots , dosent sound too bad tbh , also added oil t piece and reducer, and made oil return 19mm bore , modifyed ht leads to suilt, redone manifold had a small blowing, had to alter external wastegate still in the way but ill mod the air intake, next is modify some boost pipes , sensors, intercooler,hoses,, ive also dropped on a pair of poly bushes which ill make some new mounts from too few pics here
quick engine video
View My Video
well few more little updates as the sun was suning today ;)
first had to chop the intercooler and weld 2 cores together and modify with pipe work , as the single wasnt cooling enoegh
then welded the lot together
somert like this
then nearly forgot needed a blow off valve fitting so welded that on too lol
you can just see it here
next hit a slight problem with the outlet on the boost pipe so thought chuff it ill make a s bend as to flow few engine shots at mo
up and runing upped the boost to 15psi and feels tonnes better over the 24v lump i had in
