thebody
127
Coningsby
I just cant decide i would like my ibiza to sit a little lower but not interested in having it slammed.
As im going to be using it on long journeys i wont to retain some comfort. My old bones cant take it no more.
Im only interested in lowering it 20-30mm.
So my question is coilovers, springs or matching dampers and springs ?
Ive done a search and didnt come up with any conclusive answers.
well i'd put it this way
what is your budget firstly?
coilovers are not as what people make them out to be, mine are really soft, dare i say softer than when i had springs on my gti dampers?
springs are good for a slight drop like what your looking for
really springs and dampers would be the best option
but in reality when you drop her 20-30mm you will want to drop it even more (and i don't mean "slammed" but dropped like an extra 10mm)
all i can say is i cannot fault my coilovers tbh, but i am not running 20-30mm drop, more like 60-70mm :)
i got hottuning ones, they are perfect for what i want, they actually surpass my expectations, as i though ride would be rock hard, i was so wrong, they are really good :)
if you email [email protected] (say your on SCN and Suraj sent ya, he will sort you out cheaper prices :))
i think they do shocks and spring setups too, so worth asking, he is belgium but speaks good english :)
EDIT: when i got my set delivered, they had "TA Technix" strapping around the box, as they are actually made by TA Technix, but sold for MUCH cheaper :)
never known coilovers ever described as soft as springs before - have to keep an eye out for a set once i decide what im doing with it
mk2 suspension is already solid. might aswell have coilies just so you can hurt your back AND have a nice ride height at the same time. ive got 60mm lowering springs so its solid and nearly flips the car over bumps.
Springs on standard shocks? It's not going to flip due to a "solid" ride it's because the shocks are boucing like crazy :)
Didn't you have them off Phil? If so they were mine at one time and even Koni Sports shocks were to long for them.
Even look at Supersport because they are made in the same factory on the same line as Spax but are cheaper.... Even got told that by Spax
its complicated. i wasnt coilies. need to go lower. [B)]
Did you have to pay import tax because they came from Belgium ?
nope, just paid what edwin said, they came to my door, then shoved on, then picked the height i wanted :D
i know mate, i thought "gonna be solid compared to my springs/shocks" but i was totally wrong :D
well i am running quite low, and heard if you raise quite high you lose the helper springs (as they compress) but i wouldn't imagaine it to be too bad tbh :)
Try a Koni kit. Not mega lowering but retains decent comfort. Very old PPC article with Glyn Hopkins old car had a useful article.
I managed to get a set of 40mm koni springs/shocks cheap.
The ride is ok, it is quite hard, but I'm also on low profile tyres which doesn't help lol.
Come to think of it the dampers on mine are adjustable so the ride hardness/software can be adjusted......might need making softer lol
I'm getting some 60mm springs for the front soon, just for a better stance, but when I save up, maybe at the end of summer or start of next year I'll buy some coilies
what you mean by fitting issue's?
it's quite straight forward
more or less the same as normal shock/spring setup
just when you got it on the car i suggest you put it on the lowest setting, then adjust to the height, then spray copper grease all on the coils so they don't cease :)
Never had or been in a car with TA Tech's so can't comment but I can tell you after riding in a couple of Ibiza's with fairly new standard shocks and eibach springs I'd spend the extra on a matched kit, the ride was terrible, crashed over small lumps in the road and handling wasn't predicatable, really annoyed both my mates when they couldn't keep up with me down country roads, cars hardly kept in contact with the road the grip was worse than std.
Always go for a matched set whether it be coilovers or not, suspension working in harmony will always ride miles better.
Well i get paid on friday so will order some then.
Thanks for all your comments def gunna go with coilovers now.
good lad, coilovers are great, and for the price HT's are, (and some other makes) it'll be stupid not to :D
