Rims ET45 16 x 7.5s. What width adapters should i run to get them sat right?
ConradJellyfish
89
As The title says really, got some nice audi rims. However im realy bad at calculating ET's Etc and im not up on what ET's sit well on a mk4?
So The et of the rims i have is 45, what adapter width should i run to get them sittig nice on her dab sport 1.4.
Thanks J
mazzerati
Bags are for groceries!
Jun 27, 2008
1,980
Beverley, East Yorkshire
Standard are usually 43 but your about and inch wider so 10mm maybe 15mm
depends how you want it sat and what your tyres are like. They stretched on or fitted properley?
ConradJellyfish
89
its going to have the existing tyres swapped of the rims, so will be a tiny bit of stretch. Not Massive?
i just dont want to order adapters to find the car has shed loads of poke. Its The mrs motor, so i want to roll nice, not scrape (im not rollin anymore archs lol, i hate doing it) so you think 10's would be best?
wenman
Red Ibiza 1.8T
Mar 28, 2009
1,094
Cheshunt
Ive just tested some 16x8 Mercedes wheels and with adapters et was 21.
They were only just poking on the back to the top of the arch, however from the rear bumper they did look pretty wide!
I would go with an offset of around 30 with 7.5"
ConradJellyfish
89
What Size adapter would that be then?
J :)
mazzerati
Jun 27, 2008
1,980
To mork :)
I was just going off what size my old wheels were so dunno lol
how far Off Beverley are you then mate?
Would adapter size not be determined by how much stretch he is running tho? I'm probably wrong like haha!
What size tyres you gunna be running so I can get an idea of stretch amount :)
not to undermine this fellow ^^ cos it seems he knows his onions but just to be on safe side :)
ConradJellyfish
89
Im In anlaby, BUt Just moving to Brough :)
might off seen my yellow mk3 ibiza cupra flying about, yellow with black super t's :)
ill have alook at the tyre size tonight to determine the stretch :)
vikki
61
Beverley, Nr Hull
Dude, 205/45/16 wont have any stretch on 7.5" rims.
I would run 15 - 20mm spacers else you will have problems with scrubbing if you go any bigger or the bolts will be too long if you go any smaller.
Tell Lindsay to be a hero and run 165/40/16s.
Also to Mazeratti, My mum also lives in Beverley so might of seen a green mk2 ibiza, black azev As, bonnet bra etc...
Similar threads
