Hi Guest we, are working on an upgrade to the forum this week, meaning the service may be unreliable at times and there will be some planned downtime at some point. Stay updated on this thread.
Run it along the lip of the plastic bit under the bumper (if this makes sense.) When I fitted the LCR splitter to mine, I used this as a guide to keep it straight.
you can get the earlier laguna one without the holes...then you could fit it centrally and trim the sides off. and there are thicker bits on the top of the splitter that you can use to screw into to make it more stable.
They take a lot of abuse too and flex loads so un likely to rip off unless you are very un lucky.
