Help needed with brake disc removal
gezmeister
I need a derv!!
Apr 1, 2008
2,172
Norwich
What do i need to remove the main hub nut that holds the brake disc on? Its ribbed and i havn't got anything remotely likie that, and its taken me 2 hours so far to get the passengers caliper and carrier off [:@]
Pyro
you dont need to to take the hub nut off mate just the little glug nut
vroomtshh
4,222
Dreghorn, Scotland
The hub nut doesnt hold the disc on. There will be a little screw that holds it on. And you should have undone the screw before you took the calipers off coz the disc usually just spins otherwise
Pyro
here ya go there will be one or two screws here but hey will be really tight ;)
Feb 26, 2009
5,275
Wolverhampton
Two hours to undo four bolts? That sounds a bit wrong to me. It shouldn't need any more than a decent set of sockets, a breaker bar and some 'enthusiasm'. If you're changing discs and pads, you should have been able to finish both sides by now.
I usually use an impact driver to remove the disc securing screw, and if that doesn't help I drill the b**gers out.
Pyro
you dont really need them anyway but yea can do all four in bout 2 hours if not less
Pyro
mybe he's trying to get to the drvers side break disc from the pasenger :cartman:
gezmeister
I need a derv!!
Apr 1, 2008
2,172
Norwich
Made me lol to see the replies to this. I was just being a tw@t, i thought the hub nut held the disc on, massive fail on my part. The bolts that hold the caliper and carriers on were a nightmare, but thankfully the driver's side was much easier to do. Managed to snap the retaining screw on the passenger's side, but hey ho. Discs are a massive improvement over my crappy standard versions, and have got rid of a grinding noise i had when i broke, result!
Feb 26, 2009
5,275
Wolverhampton
I wouldn't worry about that bit, none of my brake discs have an intact retaining screw anymore!. I really ought to get round to removing the remnants of the screws and replacing them, but in real terms that screw does next to nothing.
gezmeister
I need a derv!!
Apr 1, 2008
2,172
Norwich
Yeah, bit pointless if you ask me. But they're fitted now, just gotta worry about doing the rears next month :funk:
Feb 26, 2009
5,275
Wolverhampton
The rears are a bit more challenging. Removing the caliper, carrier and disc is the same as the front, but rewinding the caliper is a task in itself. Whilst some people have had success with long nosed pliers or other tools, I have to recommend the proper tool. I think it's about £17 from Halfords, or a bit cheaper off Fleabay, and it just makes things so much easier.
sockpuppet
837
Are you sure you want to do the rears? The fronts are much easier than the rear.
Make sure you have the wind back tool before you start on the rears as the pistons on the rear need to turn as they are compressed.
gezmeister
I need a derv!!
Apr 1, 2008
2,172
Norwich
Don't have a choice. Need rear pads so gonna upgrade the discs to match the fronts at the same time.
