TT Bushes
Seat Gooner
A.K.A Mark
Feb 28, 2009
1,952
Wisbech
ermm think you should be doing what im doing mate
change all the bushes in the wishbone change the anti roll bar links and change the arb bushes
gazrhys
321
Manchester
just a quick to any one who wants to get the solid rubber front rear bushes this guy on ebay is selling them at £3.50 each item number 130419125331 dont know about the quality tho but im gonna order some on wednesday so il let you guys know what there like
gazrhys
321
Manchester
Seat Gooner did you go to audi for the 2 piece subframe bushes i tried eurocar parts over weekend they dont stock them
gazrhys
321
Manchester
yeah was looking on there but didnt seem to be any well gutted them front rear bushes is a good find tho £3.50 each the guy said there are 2 different sizes im not sure what he is on about i thouhgt they were all same size
Gulfstream
507
Ive got an uprated front arb with new bushes. 21mm, and still to get one for the back. So all the wishbone bushes then.
gazrhys
321
Manchester
there the front rear wishbone bush aint they same as these 130419125331 (£3.50 each) im talking about the subframe bushes upper and lower come in 2 pieces
gazrhys
321
Manchester
reflexuk sos forgot to order them on wednesday spent the day looking at lowering spring ended up ordering them instead from germany gonna order mine today hopefully anyway
funny thing i was speaking to an old time mechanic over the weekend tryin to explain to him about the TT bushes being solid rubber he told me not to waste my money and fill my origanal one ones with windscreen silicone ,how dodgy is that i feel for people who cars he's worked on when he was younger but i suppose that how they did things back then lol
gazrhys
321
Manchester
forgot to mention i also ordered the parts for the S3 lower brace well the nuts ,washers and riv nuts which cost me £4 .now ive just popped down to local steel fabricator and got a steel bar which should be alot stiffer than the aluminium one audi does for free what a bargain gonna fit these this weekend will prob have to paint it with some pretective paint or something cant be bothered powdercoating it
gazrhys
321
Manchester
got a question about the S3 lower brace do you have to fit it with both front wheels on the ground ie up on ramps or in the air
reflexuk
Future member
Jul 16, 2008
186
Nr Chesterfield Derbyshire
I had the same idea about the s3 lower brace. Did you get the parts from the stealers? I wouldn't think it matters where the car is when you fit it, but I'd like to see you trying while it's on the floor rofl!
What are the dims of your bar stock? flat I hope, like 4mm x 40mm I expect I don't know how long I need though?
Filling of voided bushes is not that uncommon, I've done it myself in the past, not as stiff as a polybush but noticeable when I did my micra engine mounts and far far cheaper.
gazrhys
321
Manchester
im not that slim to doit with the car on floor i meant up them ramps you drive up looking at your pic tho dont think you'd get up them its a push with mine .
I got the parts from VAG parts in stockport its where the stealers go around there if they need parts urgent ,must admit they are cheaper than stealers but not on all parts some are same as stealer (body part etc) i priced up the cupra R kit (everything) was about £1100 if i remember duno if thats cheap or not really.
The bar i got is made of steel its 10mm thick, 30mm width and i got it 23inches long so i can file ends down to a smooth finish and once i drill the holes in the right place im gonna sand it down and paint it yellow to match my calipers and also to seal it from rusting i suppose , I think the OEM bar is made of aluminium and looks like it was a tube which has been flattened i think dont hold me to it .
What did you fill the voids with on your micra out of interest?
reflexuk
Future member
Jul 16, 2008
186
Davids U Pol Tiger Seal Black Cartridge Polyurethane PU Adhesive Sealant
TIGERSEAL
Polyurethane Sealant and Adhesive
Description TIGERSEAL is a one component polyurethane sealant
and adhesive and is ideal for a number of automotive
applications. It will permanently seal and stick body
panels and trim. Will seal around windows, doors,
lights etc. It will stick to most materials such as steel,
aluminium, glass and most plastics.
Surface preparation
and instructions for
use
TIGERSEAL PU sealant and adhesive can be used on
the following surfaces:-
• Steel, aluminium, brass, iron.
• Fibre Glass and most plastics.
• Glass.
• Wood.
• Ceramics.
• Paint.
Surfaces should be clean and dry and free from
grease.
Application: Apply with a standard cartridge caulking gun.
Drying time 30-60 mins. To skin. 3mm/24 hours to cure through at
23ºC and relative humidity of 50%.
Over-painting TIGERSEAL may be over-painted with most paint
systems once fully cured. Can be over-painted once it
has skinned if using polyurethane paints.
Product codes TIG/B - Black 310ml cartridge.
TIG/G - Grey 310ml cartridge.
TIG/W - White 310ml cartridge.
