seat 1.4 motor swap
ricko23
hi there i have a 1.4 seat ibiza 1998 sxe im looking into doing an engine swap but im not shure what other motors would fit in this car i want to put in a 2.0 gti any1 know if it would fit or what i would have to do to make it fit thanks ricko:-o
vngtx
usual comments:
1. how much power?
2. wouldnt it be easier to buy a mk3 cupra?
3. try the search
4. how about a VR6 Turbo? :p (my trademark)
tony100
Newbie
Jan 10, 2006
104
g40
g60
1.8 16v
2.0 16v
vr6
1.8t
r32
just to name a few :D will basicaly all use the same engine mounts !!
ricko23
dont care about the gearbox as will buy 1 to fit and the sub frame is only 4 bolts piese of piss to take out ive got the motor out all i want to know is witch will fit best without to much modification to the loom ect the only reason im doing this is becoz i just moved here from the states and i had a 7.5 caddie coupe devill 1979 mint so im used to lots of power but out here the ins is crazy stupid so i wanna hide my power plant in a lil seat so any ideas thanks ricko
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
Stick a 1.8T in it, with a 5 speed box. Easiest to do. VR6 engines just aren't ideal for fuel economy or tuning.
Whatever you do, the engine side loom is scrap, so everything from the fusebox forward.
ricko23
ok thanks mork geoffnet now how would i go about figuring out how to hook up my 1.8t any suggestions
vngtx
gaffa tape and a hammer.
you will need ecu, pedal box and hydaulic clutch (unless you use the 2.0 16v gearbox), engine, gearbox, driveshafts and engine mounts, wiring loom, radiator, subframe, brakes, and a few other bits.
vngtx
if you were going to do it you might aswell buy a 2.0 16v with high mileage, broken engine or gearbox and start from there. very few people who ask about it actually do it. e.g me.
