turner89
Need some urgent help please guys I'm about to go out of my mind!! So after repeatedly putting my car on the emissions tester, changing parts, spending money and it still failing every time have no idea what to do next. The car is a '99 Seat Ibiza 1.4 APQ engine and so far I have given it an oil change and filter, air filter, fuel filter, recently had new plugs, cleaned out the breather pipe and throttle body, replaced a broken stud between manifold and downpipe, checked for any leaks in exhaust, replaced lambda sensor (not new but seems good), replaced temperature sensor and chucked a bottle of redex in. I've had 4 different emissions tests before, in between and after making all these changes and they all give pretty much the same readings.
Natural Idle
CO Level 0.45% Pass 0.50% Max
Fast Idle
CO Level 0.58% Fail 0.30% Max
HC Level 101 ppm Pass 200 Max
Lambda 1.01 Pass 0.97 - 1.03
Second Fast Idle
CO Level 0.54% Fail 0.30% Max
HC Level 95 ppm 200 Max
The garage says its over fueling for some reason and the baffles in the back box could be screwed. Would make sense because its sounds like its blowing but isnt. Now the only other things I can think of doing are changing the back box and the cat but obviously I dont fancy doing that. Sorry for the essay but im going mad with this car. Any ideas?!
Natural Idle
Fast Idle
Second Fast Idle
