could be many things tbh, maybe get somebody to read the codes from the ecu and that should tell you the
problem. However, i do know that the coil packs are quite common to fail on the 1.2 engines, but the signs of this are that the engine runs very rough as it is only running on 3 cylinders. Hope this helps
