I`d recommend the bottom one, the 35w slim ballast kit.. purely because slim ballasts are easier to mount in tricky places.
The mk4 beeza does`nt need the ultimate kit as it does`nt have can-bus wiring.
Just been on hids4u and can`t seem to select H7R bulbs? Maybe they are sold out, might be worth emailing them. I had to when I wanted them a while ago and had to wait a few days for them to take delivery of some.
How did you go about installing..? I really have no idea whatsoever. I guess you had to drill 1/4" holes to fit the wires through, and the rest to me is a mystery
Yeah you'l need to drill a hole for the wires, the bulbs are a straight swap and the wiring just plugs into the existing headlamp plugs... Mine was slightly more complex as I have an extra set of wiring for the high beam.
I'd say they only get *warm* to touch... I did get smoke off the one on the RHS went the ballast burnt out, still wasn't hot enough to burn the glue off the velcro as I used it to mount the replacement!
