Yeah
Remove plastic undertray by unscrewing all screws
Pull tray toward back of car to drop it down
You will need a 32 or 34 mm socket to take off the filter housing and a 17 or 19mm (cant remember sorry) for the sump plug
Remove sump plug, drop oil in to bucket
Slacken Plastic Filter housing using 32 or 34mm key, then unscrew by hand - note the screw top which is something extra to stop it coming off ( you will know what I mean when you see it)
Replace sump plug when oil has finished draining - garages use new ones.
Remove filter from housing
Put new filter in housing
Fill with clean oil
Screw plastic filter housing back in and tighten with 32-34mm socket
Put on screw top
Fill with oil - typically just less than 5 litres as memory serves
Clean underside of engine
Replace plastic undertray
Start car and idle for 5 mins
Leave for 5 mins
Check oil level
Top up if necessary.
