joehirth
Rate me up baby
Apr 19, 2010
1,896
Woking, Surrey
www.facebook.com
Apart from the engine code embossed on the little tab are there any differences in cylinder heads on the 1.8t family? I'm looking to buy a Ibiza Cupra cylinder head AGU code I think, and put it on my AYP engine in my Ibiza Cupra R. I will be rebuilding it with supertech stainless valves and getting it ported and polished, if this makes a difference?
ADR is also largeport that's what I have.
Followers are the same iirc but cams can varie due to some of the heads being from non turbo 20v lumps.
I dont think ADR is a large port. Thats a N/A 20vt small port.
AEB, AGU and i think one other one is AJL?
:confused: No idea then phil, can anybody else shed any light on it? What should the inlet port size be on a large port in mm, I'll have a measure up.
Im not sure either, be good to know tho as it gives more options on largeports.
I cant remember now but im sure bill has the info in the phenolic spacer thread.
ADR is largeport non turbo
AEB,AGU largeport turbo
I have run ADR on mine originally, the a couple of AGU's, and an AEB sitting on my shelf - all largeport
:thumbup:
Might be a daft question but what are the benefits of fitting a large port head? Do you only see the benefits on bt?
:thumbup:
Thaks Bill cleared it all up :clap: I will probs be getting an AGU head then. :funk:
tom w At an educated guess I suppose it's to allow a higher rate of air flow both in and out of the engine.
Well people I have had a measure up of the ADR code head I have sitting here and the results are as follows:
Inlet ports measure 43mm x 22mm.
Exhaust ports measure 33mm.
Part number is 058 103 373 D.
So according to the measurements on page 12 of bill's phenolic insulator thread that makes the head a SMALLPORT not a large port as previously thought.
So I now have 2 small port heads :(
Thanks a lot for that. Good to know. :)
unless ADR was available in large and smallport, and thats something new to me, the ADR head i ran was largeport with 55mm wide ports
:confused:
:confused:
That is a thought that crossed my mind Bill maybe ADR was the head in production when vw/audi started to play with port sizes so in turn there is some of each in that code :confused:.
Any idea what the part number was on your ADR Bill?
The ADR i have was from a friend who runs a specialist vw/audi brakers yard so i only gave peanuts for it, but i'm sure he had another ADR head there if not two more, next time i'm over there i'll have a look and a little measure up if there still there.
