Snow driving conditions..
Anth
Am not so sure where I was to put this query so I just plopped it here.
Last winter, I used to own a Corsa 1.2 SXi (clapper) which I got used to driving in the snow pretty quickly and had 195/45/R15 Uniroyal Rainsport 2 tyres on it.
Now I own a Seat Ibiza FR remapped a tad higher..
Anyone who has this car, whats it like in the snow and whats the best tyres for it?
Chino_UK
Team Creatine
Jul 19, 2009
1,587
Cheadle, Cheshire
Same rules apply really, just be careful with the way you apply power and gearing. I'm using Toyo Proxes 4's all round, they coped fine with the snow we had at the beginning of the year. Just have to take your time.
Guinness
Finally got the BMW
Nov 29, 2006
4,421
Newcastle
Winter tyres make a differnce if you are really botherd.
I personally cant stand my T1Rs in the snow, but I suppose that is personal preference.
Guinness
Finally got the BMW
Nov 29, 2006
4,421
Newcastle
If you have standard wheels it might be worth getting a set of spares (possible only 2). However I wouldnt recommend putting the best tyres on the front as its fairly dangerous to have worse grip on the front to the rear.
(there are loads of videos kicking around on why not too) I do understand the drive from the front wheels and the gripping better would make some sense.
Anth
The rear tyres are newish and have a good bit tread, I have Toyo Proxy 4's on the front, but they are wearing down, so seeking some new tyres hopefully ones which arent going to put a smoking hole in my wallet.
JPS3290
Dirty Diesel
Jun 6, 2003
438
Durham
Visit site
Had my Ibiza Cupra for 3 years now and also remapped with larger tyres. No problems at all. I always turn TCS off when getting out the estate or on roads badly covered in snow and just do everything smoothly and slowly.
I live out in the sticks on quiet A/B roads which often don't see a snow plough or grit and not got stuck once, yet seen lots of others in a ditch simply because they either 1. Have no idea how to drive to the conditions or 2. Drive too fast trying to impress others how bad a driver they actually are.
Should also point out I never bother changing to winter tyres. Last year I kept my Yokohama Prada Spec 2's on, anyone will tell you they are terrible in the rain never mine snow/ice but as long as your smooth and feed the power in they don't cause too many problems ;)
stezo2k
Anjuna Monkey
Mar 15, 2008
2,804
Dudley
Same here mate, they handle the snow a hell of a lot better than my old firestone ones. Great tyres I think
RUM4MO
8,099
1,117
South Scotland
am starting to think that a set of steelies may be cheaper lol
I got a set of steelies with Michelin Alpins for my wife's Polo 9N (14") to replace the lethal Michelin Pilot Exaltos (15") - like night and day really. It really depends if you need to travel on small hilly roads like she does and make good progress over a 10>15 mile jouney, or like some people on main roads with the option of using a bus over a distance of 5 miles - fitting winter tyres will cost a bit but its miles that you are not putting on your summer tyres. MYTYRES.COM will supply steelies complete with winter tyre and I'd always suggest you buy a complete set, only buying 2-off means that you don't really need them.
Remember winter tyres will help you to 1) start moving + 2) keep moving + 3) slow down and stop, in snow and ice and everything else when the temperature is below +7C. Never be put off by Southern dwellers when asking these questions - where some people live you should consider fitting winter tyres, where other people live it might not be necessary.
Modelmakerman
Mk4 Ibiza FR TDi
Apr 24, 2010
368
Bristol, UK
www.modelmakerman.com
I have a LandCruiser with 33" Mud and Snow tyres that I use in the winter, means I save my Ibiza from being hit by morons who cant drive and shouldnt be out in the snow. It doesnt matter if they hit the LandCruiser............. It'll win (tried and tested with 2 cars last year!)! :D
Obviously having another car for the winter isnt particularly affordable or practical for most people so the best bet is to get proper winter tyres. I think that if the weather is as bad this year as it has been the last 2 years the government need to start thinking about bringing in legislation saying we need to change to winter tyres like they do in other parts of Europe.
Winter tyres make so much difference and you can buy a set of remoulds very cheap, its not like they are going to cover a load of miles or at any real speed and if you get them on another set of wheels you can swap them around easier and they will last you a few seasons.
The biggest thing though is knowing how to properly drive in the conditions. Every time it snows I loose count of how may cars I end up pulling out of stupid situations and I have refused to recover people on the basis that I saw how they were driving to get themselves into the hedge/ditch/tree/field etc.
A few tips on winter driving:
NEVER use 1st gear to pull away, its too low and will always spin the wheels. Always pull away in the highest gear your car is capable of pulling away in (usually 2nd but possibly 3rd on a remapped TDi)
20mph is fast on a snow covered road, keep it slow then if anything does happen you have more time to react and less damage will be done.
Keep all your inputs smooth and progressive.
Use the brakes as little as possible, use the gears to slow the car but make sure you equalise the revs before dropping the clutch otherwise you will lock the wheels anyway.
Dont trust the ABS or TCS, they dont work too well in ice and snow.
Always leave a big gap between you and the car in front, at least 5 car lengths, even when stopped as you never know if they will slide backward. If someone fills your gap then drop 5 lengths from them too.
Always follow the existing tyre marks (unless they end up in a hedge!), never be tempted to stray onto the uncleared part of the road, this is usually the start of where it all goes wrong.
Only drive if you REALLY need to; will walking to the shop kill you? If you dont need to go out then dont, driving in the snow is fun...................... until you or someone else messes it up and then its gets expensive and dangerous very quickly. It doesnt matter how good a driver you are the other people on the road usually arent and good. Its not big or clever to go out "just for fun" dont give in to peer pressure of others saying its fine.
Dont get complacent, if the road conditions get better be carefull how much you speed up and still keep driving as if you were on snow as conditions can change very quickly and back ice is deadly and invisible. If you go out and arent confident with driving in the conditions dont be afraid to turn back, its better you do it while you can and not 5 miles up the road where its worse and you cant turn around.
Lights, If youve ever driven in a blizzard or really heavy snow you'll know that visibility is virtually 0 especially at night, if you have fog lights use them, if you dont try winding you headlight levelers down so the lights point down this way it stops the light bouncing back off the falling snow and dazzling you. You can try the levelers whilst using fog lights too but sometimes foglights work better with only the sidelights on.
If the sign says "Road Closed" it means it! If you see me going past the sign, take note of the 4x4 with decent tyres, orange beacon, winch, CB radio, tow straps, shovel, blanket, first aid kit, fire extinguisher etc etc. Im probably more equipped than you to tackle the problem ahead and Im probably carrying a police officer/doctor/nurse and/or food and medication for the old biddies snowed in in the little village at the other end of the road.
Oh and above all: If it does all end in tears and some nice fella in a 4x4/tractor etc. comes and sorts you out say thank you and give him something for his trouble, youve probably made him late for wherever he was going. ;)
Hope this helps. :)
Modelmakerman
Mk4 Ibiza FR TDi
Apr 24, 2010
368
Bristol, UK
I wish I got paid for it! I am a member of a 4x4 response team, we help the local emergency services when the conditions are too bad for them to cope.
BMWs are useless in snow unless they have a few bags of cement in the boot and even then the driver is still a beemer driver! :p (one of the cars that drove into me last year was a beemer driven by an idiot, he found the military tow hitch on the LandCruiser; Landcruiser - chipped paint on hitch, BMW - hole in grille and radiator, headlight smashed, bonnet bent.........whoops! :rolleyes:)
