sunny2k2000
Under the Hood!
Sep 4, 2008
121
Leicester
I start the car from cold, idle for 30sec then drive softely until engine warms up which takes around 15-20mins, i then start the heating.
Is this normal, also is turning the heating on from a cold start OK?
Discus please...
mines a petrol and i turn heating on just after it starts rising, no point blowing cold air is there. It takes around 5 mins of steady driving to get to 90 Degrees. When i used to have the polo tdi though it was about 10 mins
The freezing weather dont help. Mines taking a lot longer compared to a couple of weeks ago (usally 5 -10 minutes now about 20). If you car is kept outside will probaly take even longer.
diesels always take a hell of alot longer to warm up than petrols. Infact in my diesel van, if I allow it to idle long enough the temp gauge can go from 80 back down to a indicated 0!!!
Having my climate control set to auto means that it doesn't speed up until the engine is providing heat. That's usually at least ten minutes into the journey.
I don't turn mine on for about 5 mins as it slowly blows cold when just started unless it's summer, takes about 5 minutes for the temp gauge to start taking a reading. And I don't go over 2k revs (ish) until this happens.
I live next to a motorway though and if I get straight on there from cold the temp will be up at 90 in less than 5 mins at 70 mph.
I leave mine on auto low set to 20c and never touch it. As soon as it can provide warm air it does. My old car when set to auto wouldn't blow ANY air until it could provide the heat that you wanted.
I seem to remember reading that diesel engines burn cooler, less of the energy from burning the fuel goes into heat than with a petrol engine.
According to the manual it is supposed to be quicker to hear up the cabin if you have it on the setting where it only re-circulates cabin air and not outdoor air.
Ye that's so that it puts warmer air through the heater from the cabin rather than clap cold air from outside. But obviously the heater's need to be blowing warm air in the first place! Same with air con and cooling
As soon as you switch on your climate control, the fan behind the radiator starts up and sucks cold air through the matrix. Therefore it will take the engine longer to heat up. Give it a bit longer to allow some heat in the engine first then put on your climate/heater fan. Works for me:)
