You Know You have a mk2 Ibiza When........
Finan
i went jap.. :O
Jan 18, 2009
908
Eíre
bebo.com
You know you have a Mk2 Ibiza when everything goes wrong overnight and on the coldest morning ever you have to fix them.
brrr freeezing lol.
my central locking is broke again :(
crossedmike
You know you have a mk2 Ibiza when you do a 12 hour shift at work then spend 3 hours in the garage After that nearly everynight just because you know it will be worth it :)
Also you know you have a mk2 2.0 16v when it refuses to come apart because it's scared of the new heart it's getting
Mythbuster
352
Made, The Netherlands
You know you have a mk2 Ibiza when you reverse your rear side into a mailbox that's standing completely loose and yet there's a 1 inch deep dent in the rear quarter panel... :cry: And I just tried to fix some rust on the sills but didn't yet put red lead on it... It probably thought I was attacking her...
And you also know you have a Mk2 Ibiza when you tell your mate you bet on it that it won't start after such a thing... (It did, but still...)
And you'll be even more sure you have one when you can push almost the entire dent out with the back of a screwdriver, without really leaving a trace except a few deep scratches...
Still...
BALLS :cry: Only 1 mph...
Deleted member 32025
You know you have a mk2 Ibiza when you put coilovers on and after a month your dashboard decides to start to vibrate and you can't find where the noise is coming from..... and it slowly drives you insane......
vngtx
screw lose behind the glovebox? or is it the fascia panel in the middle?
it's coming from somewhere in the middle yeah, if you apply pressure to the top in the middle it stops. I know its not my head unit but that's about it.
Mythbuster
352
You know you got a mk2 Ibiza when your engine nearly overheats after doing some spinning and sliding in the snow, at no more than 4000RPM, for about 15 minutes while it's about 0 degrees outside!
And..
You know you got a mk2 Ibiza when the fan only kicks in when the coolant meter is already almost in the red! :? (That's how I noticed it was in the red.. the fan turning on!)
Strange, strange cars these things are... :p
Developed some strange tic/rattle while idling too, or while driving at constant speed... Hope it's just some interior thing coming off...
Ash.
You know you have a mk 2 Ibiza when everytime you pull up to a junction or traffic lights it cuts out and wont idle.
crossedmike
:lol: and a laptop and a set of speakers and a floor heaters. wish i had a heated double garage be a dream come true!
haha i have alittle electric heater which warms it up well and a bosch drill charger with built in speakers so ipod connected and dance and convert lool still need a 40 inch on the wall lol juct for the tea breaks ;)
Big-Pete
Always on the Limit
Aug 8, 2010
3,032
sounds right mate doing my lower arms soonish :) cant wait to take my knuckles off :(
